- 510
the F430 does push 500 BHP, its more like 460.
I don't know about that, dynos I found reported 424rwhp, 432rwhp, 410 rwhp, and 427 rwhp. Seems right around the 480-500 range at the block..
Yes, that's doable. Let's take the case of a Honda S2000 as an example. It's 2.2 L but pushes 240 hp with 162 ft/lbs of torque. However, I don't know how twin S2000 engine can be positioned inside an engine bay.I have no doubt a 3UZ could make the same power and still be streetable.
Add dual VVTL-I, bad cams, some tuning and job's done. if the 2ZZ-GE can make 190HP from 1.8 liter and still be streetable, the V8 can also achieve the same output.....
jibby, did you know that the lexus rolex race car uses a modified 1uz that displaces 4.35 and makes 500+ hp at 8,000rpm?
so, UR, ZR, GR...
they'll be like all the same engine, uses the same pistons, rods, cams, intake systems etc etc. ???
Just like the UR is a 8 cylinder version of a GR engine?
