hypronet
- Messages
- 274
- Location
- NSW Australia
HI Fasteddie,
Yep, the gearbox was modified to suit this engine combo an MV said that it was good an rated it for 900HP.
From my understanding, HP is not wont kills a gearbox, its torque?
There is a person that i know, that is using the same type of gearbox as me behind a turbo 2JZ, they had problems with there box, but they blow the seal out off the pump inside the box? Not sure if it the same issue as what i having?
I dont monitor the gearbox temp, but i do run a external 11 row trans cooler.
I am looking at setting up some gauges now to monitor engine water temp, engine oil temp, engine oil pressure, water to air intercooler temp(when installed) and now a gearbox temp.
____________________________________
http://www.lextreme.com/forums/showthread.php?t=9037
[FONT="]:sgrin:There is No substitute for cubic inch, except for BOOST !!!![/FONT]:sgrin::burnout:
"91 LS400" Argo rods, CP pistons 9:1, Custom Tighte Cams, Whipple supercharger 20psi, Torsen Lsd,
Dual TB's, Whiteline swapbars, 97 RZ Supra brakes, Airbag & controller
