hi pwd,
good to see that you still have the car
what sort of boost are you getting, are you still running about 8psi or is it more now?
i will look into that as well with my manifold, as i noticed that mine too sounds a bit off down low at times?
did u port the manifold or is it still in std form?
____________________________________________
http://www.lextreme.com/forums/showthread.php?t=9037
[FONT="]:sgrin:There is No substitute for cubic inch, except for BOOST !!!![/FONT]:sgrin::burnout:
"91 LS400" Argo rods, CP pistons 9:1, Custom Tighte Cams, Whipple supercharger 20psi, Torsen Lsd,
Dual TB's, Whiteline swapbars, 97 RZ Supra brakes, Airbag & controller
Yea mate still got it, had it to long to part with it.
It has 12lb of boost now, but had pinging issues, so the timing has been retarded to a maximum of 9 degrees to keep it safe because I ran out disposable income to throw at it,
Things are slowly picking up so soon I will be able to do the things I need to do to sort it out and get the figures it should really have.
I did not port my manifold, just left it as is.
