kc95sc400
- Messages
- 524
- Location
- Charlotte, NC
Hey guys,
I know I don't post over here nearly as much as I should but I thought I'd share this.
I ran the 1/8 mile last night and had a best run of 8.285 @ 85.885 mph on street tires. Based on some 1/4 mile runs I've made recently, this time should equal at least a flat 12.8 quarter!
Quick list of mods...
95 SC400
Un-opened motor
The Fish with a Vortech V-9 2.25 inch pulley about 9-10 psi
FMIC
Colder than stock plugs
Bypass valve vented to atmosphere
315 Supra injectors
Supra turbo wheels 275/40/17 rear and 245/45/17 front
Supra struts with swift lowering springs
2.5 inch exhaust with 3 Magnaflow mufflers
Stock gears with Supra Torsen center
EKT headers
Transmission accumulators shimmed
Transmission line pressure increased
Dragon convertor 2800 rpm
Coolant bypass, IAC and throttle body
170 degree thermostat + redline water wetter
EGR deleted
MaftPro piggyback running MAP, MAF sensor long gone
Spare tire replaced with fix a flat
Current plans - going to put in a newer transmission. Hopefully this will fix a little problem I have bouncing off the rev limiter on the 1-2 shift.
KC
95 SC400
Un-opened motor
FMIC
315 Supra injectors
EKT headers
EGR deleted
KC
