hey guys I have a question for you. i have been talking about this with several people and I get different answers so I would like to try to better understand what sort gains to expect from supercharghing or turbocharging. Here is the scenario. (All horsepower figures are at the crank)
I have a 400hp 1UZ-FE engine due to cams, ported heads, exhuast, and intake. Some people say that I will make as little as 450hp if I put an intercooled turbo system on that engine while others say it will be as high as 550hp. From what I understand the amount of power is directly related to how much air and fuel you can put into your engine. So if you have two naturally aspirated 1UZ-FE engines (4L V8), and one makes 300hp and one makes 400hp, obviously the amount of air flow between the two engines differ, or one engine is more efficient then the other, or both. So lets say that is at 0psi boost or at 14.7psi absolute pressure. (For this topic lets just use the boost pressure, which is 0psi when naturally aspirated) Lets say that the two engines mentioned have different amount of air flow. The 400hp engine has more air flow. So if we add 8psi to both engines the airflow should increase by roughly 50% in perfect unreal conditions. So if the 300hp engine flows 30 lbs/min and the 400hp engine flows 40 lbs/min with no boost, after applying 8psi the theoretical flow would be 45 lbs/min for the 300hp engine and 60 lbs/min for the 400hp engine. Each engine would gain 50% airflow and 50% power. (Yes I know this is not real. In reality there are many other variables that prevent you fom getting that full 50% gain in power.) So with that theory both engines of the same size should get the same percentage of increase in power from the same amount of boost.
This seems to make sense to me as the turbo on the more powerful engine has to actually push more air in order to achieve 8psi. So if you had a 1000hp engine and you added a turbo, that turbo would have to push a lot more air then a turbo on a 300hp engine to achieve the same psi. (That makes sense as they make different size turbos for different applications etc)
So if I turbo at 8psi my 400hp naturally aspirated engine, what sort of hp shoudl I get from it. From the math it will make a theortical increase of 50% which is not possible due to many factors. I do plan on using an intercooler so that will help with the amount of power increase. I think a realistic 30-35% would be what I would expect. That would give me roughly 520-540hp at the crank. That sounds on the high side but the Rod Millen supercharger adds 70-90 WHEEL hp at 4-6 psi, which translate to roughly 82-105 hp at the crank increase. That is about 40-50% increase on a stock 1UZFE engine. And the twin turbo LS400 on this site had a gain of 152 WHEEL hp at 8psi, which was about an 88% increase in power over a stock 1UZFE. And both these examples are not intercooled.
Granted, I would need a turbo powerful enough to give me 8psi for the flow requirements of a 400hp naturally aspirated engine, but that 8psi shoudl still yeild roughly the same percentage in power increase. And wouldn't a turbo make more power in terms of percentage on an engine that has a better intake and exhaust (ie. free flowing engine) as compared to a stock, restrictive engine. So please any advice or opinions or ideas woudl be great. Thanks!
