jibbby
- 3,824
- Santa Monica, California
I used Mopar cumbustion cleaner once before with my older Chevy's, I removed the plugs and filled up the cylinders till it spilled out the plug holes and then turned the engine over a few times to hit all the areas of the combustion chamber....Let the motor sit over night.......Many years ago I did this and forgot.....I then reinstalled the plugs and ran the motor no change just a lot of smoke....I think this is the same, right?....
I would bet the seafoam will foul the plugs...Toys?
Oil seafoaming do you drive the car or just let it idle for 30 minutes and then change the oil? What about the tranny?
How about running the seafoam thru the fuel that way you can clean the rails, injectors, and engine internals all at once as the fuel and seafoam is run together thru the motor? I can imagine the fuel filter may clog, what do you think of that?...Is the seafoam a fuel stabalizer and can it be run thru the fuel?
Lastly how about all this crap coming out the exhaust, will the carbon deposits that are built up over the years clog the cats, or mufflers?
That should end my questions? Toys you da man, do you want to take a crack at some of my final questions? I am going to turn you into a seafoaming expert by the time this thread ends...
