Just call me "Lex"
- 12,033
- City of Halos
Ok,
Its finally here. Just pick-up my 2UZFE shortblock for my SC470TT project. This engine is a work of art. Here are the specs.
Block: Tundra 2UZFE 4.7 Iron block
Crank: 1uzfe crank
Main: 4 bolt main from 1uzfe VVTi conversion
Rods: Eagle ESP 3D H Beam with L19 ARP bolts Atomic Speedware Sponsored
Pistons: Custom Ross forged 8.5:1 Compression
Pins: Heavy duty Ross pins
Rings: Total Seal heavy duty custom rings
Bolts/Studs: ARP 11 mm main bolts (4 per main)
Head Studs: 7/16" drilled and taped
The engine also got VIP service. TLC everywhere..
* Hot Tank
* Align Bore (.02" over)
* Align Hone
* Deck
* Power Hone
* Convert to 4 bolt
* Pin fit rods
* Resize
* Balance Assembly
* Grind Crankshaft
* Full Assemble
Here are some pictures....
Crank: 1uzfe crank
* Hot Tank
* Align Hone
* Deck
* Power Hone
* Convert to 4 bolt
* Pin fit rods
* Resize
* Balance Assembly
* Grind Crankshaft
* Full Assemble
