mshawari1
When you remove an old timing belt "No marks on the belt" and you want to install it again …
You don't need to install the crank pulley to make it on "0" mark .. there is a small mark on the oil pump wall indicate the "0" mark .
After you put the crank on "0" and align the L cam to the mark and make the R cam off mark by on tooth CW .. install the belt and install the belt tenser and the R cam will be on the mark exactly ..
