General
Engine: 6 Liter V12, 60 Valves
Length: 172 inches
Height: 42.5 inches
Weight: <2600 lbs.
Width: 76.7 inches
Wheelbase: 103.5 inches
Body Style: 2 Door Coupe
Driveline Type: Mid Engine, Rear Wheel Drive
Engine Specs
Type: V12
Displacement: 6 Liters(exactly 6000cc's/366 cubic inches)
Asperation: Natural
Redline: 10000 RPM
HP @ RPM: 600-? @ ?
Torque @ RPM: 500-? @ ?
Block Material: Cast Aluminum and Cast magnesium
Cylinder Head Material: Cast Aluminum
Fuel Delivery: Direct Gasoline Injection
Valve Train: Hydrolically actuated, computer controlled, 5 pull type valves per cylinder
Bore x Stroke: 88mm x 82.2mm
Combustion Chamber: 36 cc's
Piston Dome: -.5 cc's
Compression Ratio: 14.5:1
Maximum Valve Lift: 1.25 inches
Maximum Duration 300 degrees of crank shaft rotation
Intake Path: Air is pulled(pushed at speed) into the dual air boxes positioned over and ahead of the rear wheels, through the air filters, and into the engine intake ducting. Each bank of cylinders has a common plenum with ITB located inside of the air horns. From after the throttle bodies, the air enters the extrude honed, polished cylinder head and into the cylinder. All intake parts except the throttle bodies are made form Carbon Fiber, throttle bodies are cast magnesium.
Exhaust Path: Exhaust gasses exit from the cylinder head and into a tuned, equal length 6-2 titanium headers w/ 1.5" piping. From the headers the spent gasses enter a 3" full titanium exhaust system(for each 3 cylinders), a 3" high flow catalytic converter(for each exhaust pipe), and a high flow muffler(each exhaust pipe) and exit the vehicle in quad pipes located above the spillter/spoiler.
Sump Type: Dry Sump w/ oil cooler and tri-pumps
Notes: Engine is a V12 with siamesed, cast titanium cylinder walls. Pistons are thin wall steel and connecting rods are forged titanium(H-beam). Crank is forged titanium. Intake and exhaust valves are titanuim. Engine uses no head gaskets, just compression rings.
Weight: 540 lbs
Cooling Specs
Engine Radiator: 55mm thick Aluminum Racing Radiator w/ 20 PSI Raditaor Cap
Thermostat: 160 Degree thermostat
Raditator Fans: Dual, electric 3500 cfm pull fans w/ shrouding
Engine Oil Cooler: 20 mm thick
Trans Oil Cooler: 20 mm thick
Weight: included w/ Engine
Suspension Specs
Front Type: Double A-arm layout with hydrolic pushrods(ride height adjustment) and adjustable coil-overs.
Rear Type: Double A-arm layout with hydrolic pushrod(ride height adjustment) and adjustable coil-overs.
A-arm Material: Hollow Forged Magnesium surrounded by Carbon Fiber
Weight: 150 lbs
Brake Specs
Front Brakes: 15.5 inch ceramic composite brakes w/ 8 piston, fixed, monoblock calipers
Rear Brakes: 15.5 inch ceramic composite brakes w/ 6 piston, fixed, monoblock calipers
Weight: 80 lbs
Trans-axle and Differntial Specs
Trans Type: 7-Speed SMG, trans-axle
Clutch Type: Triple Carbon/Carbon Dry Clutch
Gear Type: Constant Mesh Dog Tooth
Transmission Case Material: Cast Aluminum
Gear Material: Forged Titanium
Differential Type: Electronic LSD w/ Individual Wheel Speed Control
Axles: Carbon Fiber w/ high strength U-joints.
Weight: 550 lbs
Shift Method: Sequantial Shift Lever, not uncommon to those used in ALMS GT1 class racecars.
Body Construction
Front fenders, hood, and front facia are made up of Carbon Fiber. Radiator cradle is Carbon Fiber. Rear clip is Carbon Fiber. Deck lid and Wheel Wells are Carbon Fiber. Roof is carbon fiber.
Weight: 110 lbs
Aerodynamics
Front Downforce: 250-350 lbs @ 60 MPH
Rear Downforce: 350-500 lbs @ 60 MPH
Front Downforce Devices: Brake Ducting, Rear Radiator Ducting, Front Splitter, Front Under Body Venturi, Radiator Access Panel.
Rear Downforce Devices: Intake Ducting, Brake Ducting, Rear Double Spoiler, Rear Diffuser and Under Body Spoiler, Rear Under Body Venturi, Mid Under Body Venturi.
Frame Construction
Frame consists of Carbon Fiber/Aluminum Honeycomb. This frame surrounds all of the engine and transmission and is connected to the Carbon Fiber Tub.
Weight: 350 lbs
Safety Specs
Seat Belts: 3-point belts for driver and passanger.
Airbags: Front driver and passanger airbags. dual side airbags.
Assists: TCS, and ABS
Roof arches are made from Carbon Fiber and Titanium-Aluminum Honey Comb for rollover protection and weight savings. Roof is made of Carbon Fiber.
Weight: Included w/ Interior
Interior
Seats: Carbon Fiber framed suspension seats covered in Leather. Manual adjustability.
Dash: Leather Covered Carbon Fiber with Glove Box
Instruments: Center: Tachometer, Speedometer, HP; Left of the Steering: Oil Pressure, Water Temp, Engine Oil Temp; Right of the Steering: Transmition Oil Temp, Fuel Level, G rating(accel, decel, and lateral G's)
AC and Heat: Climate control
Steering Wheel: Leather covered Carbon Fiber. Adjustable by tilt and telescope.
Center Console: Leather covered Carbon Fiber w/ Sequential Shift Lever at the right(or left) of the steering wheel.
Trim: Brushed Aluminum
Weight: 250 lbs
Rims and Tires
Construction: Forged Magnesium, 8-spoke.
Front Rims: 285/35-19
Rear Rims: 345/35-20
Weight: 80 lbs
Engine and Chassis Management Specs
Engine Management: Single processor; handles ignition timing, fuel injectors, valve timing, sensors, trottle control, transmission control, and differential control.
Chassis Management: Single processor; handles ABS, Traction Control, and suspension adjustments.
ive been rethinking alot of the specs on this... you could call it a dream car if you want . i also rethought the valve system i thought up a few months ago, and revised it for pull type valves instead of poppet type valves. ill post more on that too.
notes: the car is meant to run on alcohol fuels only. due to the high compression ratio, and for HP reasons
