Miles B said:Nope, 415 comes outta the old "450hp" 488ci motor. My guess is they just underrated it?
I don't know about the new exhaust on the 505/500, but the 488/450 had two generations of headers.. the second was slightly better - adding it to the old generation yielded about 8-10hp. The A+ exhaust system was on an otherwise stock car - it went from ~415 to ~460 from memory.
Most of the gain comes from headwork. I believe most of the high 500s cars got about 40 from exhaust and intake, 20 from cam, and the rest from heads and tune.
I have no idea if the UZ would be better than the Viper motor with exhaust. I believe, for a 2V motor, they put a hell of a lot of work into designing the heads. Who knows what goals the Toyota guys had in mind, I know the Viper team was only after performance. Mileage is absolutely disgusting on that car.
I'd really like to see what would happen if a decent tuner, experienced at head and cam work, took on this motor. I've seen some motors produce very little after a lot of head and cam work... others like the Viper just go crazy..
Miles, didn't you say that NZ tuners are already pulling 450hp out of the early 1UZFE engine? If you agree with me that that engine is actually 230hp stock your example is nearly double the power. The stock engine has minimal valve lift and duration and horrible exhaust manifolding an passable intake manifolding. If you do not care about low rpm smooth operation it would be easy to run big cams with good manifolding and make a MAJOR jump without going into the engine.
You are correct about different heads responding better than others to port work. Of course what works on one geometry may fail to produce on another. www.motoman.com Pat McGivern makes some very interesting points regarding flow and claims performance gains in making motorcycle intake ports SMALLER! Before anyone dismisses his theories I highly recommend signing up and reading his 24 back issues. Great stuff!
It is also very interesting that the 450hp Viper dynos at 415rwhp. Less than 8% drivetrain loss if you believe the factory rating. My guess (especially with the heavy parts and wide sticky tires) would be 17-18%. At 17% the "real" flywheel output would be 500hp. Under and Over rating of engines occurs all the time. As I just said I believe the original 1UZFE made 230hp flywheel. The upgrade in 1995 to 260hp was actually a 30hp increase and shows up in the performance and dynos near 200rwhp. The 1998 at 300hp rating shows up at the dynos as 235rhp or so. In Japan 280hp was the highest official rating for most cars and was in many cases pure beauracratical BS.
	 It certainly makes sense to me that chamber design can help with detonation.. thus why my bike ran 11.7:1 on 98RON (US 93) octane fuel, and is supposed to still be able to take a bunch more advance... whereas an old chevy small block with that sort of compression would start getting pretty angry.
