Quadcob
- Messages
- 110
- Location
- Ipswich, Qld
When carrying out engine transplants and doing manual conversions in Australia there are a number of companies that supply the necessary components to enable almost any conceivable conversion. When doing the ground work to be able to buy the compents to allow a trouble free conversion you log on to forums, talk to companies and listen to anyone who might know something about conversion you are undertaking.
In my case I am fitting a 1uzfe motor with a R154 gearbox into a kit car.
The motor selected was a result of research I was doing when I was going to purchase a V8 Soarer. Decieded to build a kit car instead and use a Toyota V8. The gearbox selection was result of what I read on this forum. I was going to use a W58.
There are manual conversion kits available from two companies that I know of, CRS and Dellows. My research for a conversion kit started by checking the companies website and talking to them by phone, reading forums and talking to companies who specialise in gearbox conversions.
In the end I decieded to purchase the kit from CRS. Their kit was more expensive than Dellow due the an additional spacer reqiuired for the R154 gearbox. The kit cost $1565 plus delivery.
I have now received the kit and to help anyone else who is also about to purchase a manual conversion here are few things I found out.
1. CRS will only sell complete kits. They will, if you are persistant sell the kit at a reduced price without the clutch and pressure plate.
Dellows sell all their products separatly.
2. CRS's flywheel comes complete with ring gear. Dellow will place your old ring on their new fly wheel for an extra cost.
3. The CRS kit has secondhand slave cylinder, pivot ball and clutch fork. I have received a 2nd slave cylinder because the first one was full of rust. Even the second one might need a re-sleeve
4.CRS supply a nose cone extension for the long input shaft gearbox. Havn't worked out what mod is required to fit it(no instructiuns supplied)
5.With the CRS bellhousing a small portion of the aluminuim sump is removed to allow the slave cylinder to bolt into postion.This removes one of the bolts that holds the bellhousing to the aluminium sump. The Dellow one, from pictures I have seen, must mount their slave cylinder differently. The picture shows all 10 bolt holes on the bellhousing.
6. The CRS bellhousing has no provision to bolt on the small dust cover to the front of it. These dust cover bolt holes can be clearly seen in the front of the Dellow bellhousing picture.
7. The CRS belhousing require 30mm spacer when being fitted to the 190mm input shaft R154 gearbox. Dellow make a bellhousing for this gearbox without the need of a spacer.
I would have like to known a few of these things before I bought my kit. I would have ask more relevant questions. I might have still bought this kit, but there would have been no suprises like....grind away a small portion of...
If anyone has bought CRS or Dellow kits what have been your thoughts.
Warren
Warren
