AndreasMet
OK, so I swapped out the motor and connected all the stuff and everything looks correct.
I insert key in ignition and all electronics (dash, radio, etc.) come-up as if ready to start.
I'm not sure if I have auto shifting in proper set-up so maybe this is an issue.
So I put a jumper into the starter relay terminals to bypass the pre-ignition logic. The starter turns over, but the motor does not start.
I'm not sure how long the FI system takes to prime again, but I would expect it to take very little time.
Any advice to at least get the motor going will be greatly appreciated.
