Oh and i got another question. How had is it to change the valve seals? Where can i get a spring compressing tool if my buddy doesnt have one. I dont want a POS eather.
Valve seals are not that bad, but make sure the new ones are well seated on the guides. And you don't need a spring compressor. Have a look at this Valve Master tool from http://www.toyotool.com/. This thing makes short work of reinstalling springs, retainers and keepers.
If everything goes well, ill have the motor put back to gether by friday night. still waiting on a few rod bearings to come in. He do yall know if I have to pull the crank out change out the oil pump? Kinda need to know by friday. I havent really looked at it yet. I have all the pistons out right now. I wasnt going to change the main bearings, but if i gotta pull the crank out then i might.
The upper pan has to come off, but definitely not the crank. Be sure to use a good gasket between the oil pump and its pickup. Our member RedSupra tipped us off awhile back that the OEM gasket for the MKIV Supra, which is rubber impregnated, fits & works fine. The gasket included in the cheapie eBay gasket kit for this is cardboard.
p.s. Be sure to buy, and carefully install, a new OEM front main seal. Don't reuse the one from the old oil pump. Personally, I wouldn't trust the seals in the eBay kits for something this critical.
Here's a photo showing the underside with the upper pan off, so you can see the oil pump on the far right, and why the pan has to come off before the pump can be pulled:
