Fuel pump ecu
Big
Hi guys..I've just about done with the engine bay side of things:yeah: ..just one question:33: ...Does the ecu look,need,want a signal fromt the fuel pump to say it's there and then start?So far I have the starter on 1 relay,Main efi relay triggereing the ignitor/injector relay..will I need to loop to get the fuel pump signal to another relay..? once this is done I have to just swap the inlet manu around so the TB can be routed around without hitting anything..lol. any help would be great..cheers keri:headbang:OR can I just run a relay seperate to the ecu and have it doing it stuff without talking to the ecu..
we use the alternator circuit to trigger the fuel pump when using soarer ECU. What is your fax number and Ill send it down - cheers
Thanks G for sending the fax..wifee forgot to let me know it came last night..:flirt: but i have it now..cheers..One thing though G..why use a bypass wire?etc..not sure on that bit..LOL ttyl cheers
A tachometric relay is a good idea as well. We use a bypass relay so otherwise the starter motor will stay engaged when the relay switches - cheers
