I ordered the valve clearance shim adjusting tools from toyota which arrived today. What a rip off! If you need them, you need them... I'm planning on making up some of my own design from stainless steel to sell at an affordable price....if anyone is interested.
The cams are fitted now and I;ve measured the valve clearances and noted them all down. Out of the 32, only 1 of them doesnt need changing. After checking through all the sizes I have with the original shims...I need to order nearly a whole new set.
I plan on setting the clearances within the owners manual specifications, but at the tighter end..that's 6 thou inlet and 10 thou exhaust. My reason being that all the valve gear is brand new and I would expect it all needs to seat it self and wear into position so that should keep everything within spec for a longer period of time.
Rather than order the new shims from toyota who will overcharge and probably delay me a few weeks while they source the shims I want...I've found this place :-
www.precisionshims.com.au
Only found them by luck...I was chatting with my brother in law a few weeks ago and he dragged out a motorcyle magazine to show me one of the small ads in the back.... there was the ad for precision shims. A quick check on the internet and it turns out they are located about a mile away from where I work !! You dont often get luck like that ? I called them this morning with a list of all the shim sizes I needed. They guy called me back about 1/2 an hour later with the news that he had everysize I needed on the shelf ready to go! and for AU$10.50 each including tax, I was sold. I've picked them up this afternoon and can report they look excellent quality, the case hardening looks well done and uniform. The only drawback being that they dont have the hole in them for easy removal....
I also asked him how he would feel if I had to return a few shims to swap them for different sizes...he said that was not a problem!!
Elliot
