Got a bit more done this morning. Its all going together in a weird order, I should be fitting the pistons and rods now, but I'm waiting on some tools I bought on ebay to make the job easier, so for now I've started on the front end. Fitted a brand new oil pump supplied by lextreme, nearly forgot to replace the o ring on the block, but rememebered at the last minute. I've discovered some slight differences in the castings from the original oil pump and the new one. Nothing that will affect the engine in anyway, just minor changes.....
The bolt hole on the very bottom left is drilled through on the old and tapped on the new.
The No2 Idler mounting point does not have the steel round top hat washer, instead there is more alloy casting to make up the space and has been machined.
Looks like a new mould for the casting too, as there are also other casting changes.
Anyway, it appears to fit fine. I've fitted brand new idler pulleys and they all seem to line up correctly with each other and the water pump pulley. Also pressed in a new crankshaft seal and fitted the toothed belt drive wheel.
Elliot
