How are you going with the install for this? I'm wiring mine up at the moment after getting the info to wire up all the standard sensors, igniters and even the 6 wire ISC. Happy to pass on what I've found and we may be able to share ideas.
Yep its going great all wired up and running sweet.. only little problem was that i had to swap two wires around on the stepper motor to get it to go in and out the right way
Any details on that, I was just going to guess? I'm in the middle of wiring mine right now, just got it back with the new software upgrade from EMS.
I was going to use the following, assuming the pin wiring is correct on the ISC plug:
ISC ----------- Crown ---------------- EMS
Pin Plug wire colour)
1 Blue ISC 2
2 White 12 v Ign
3 Yellow ISC 4
4 Green ISC 1
5 Black 12 v Ign
6 Red ISC 3
I have decided to add my personal notes on learning the ems 8860
1uzfe Crown
Oh I should add I am not a mechanic and most learned the hard way.
A great idea do not hook up the injectors until after you have checked the timing with A timing light. If you cannot get it firing at about 8 degrees then most likely replace the crank angle sensor or the settings in the software are wrong.
trigger mag, and sync sensor mag
number of the per cam cycle is 24 teeth .
static timing teeth none.
The crank shaft sensor pin 1 on the 26 pin plug black goes to green on the shielded trigg wire.
no 1 cam sensor pin 15 on the 26 pin plug goes to yellow on the sheilded sync.
