91_4x4runner
- Messages
- 260
- Location
- San Antonio, TX
I'm starting with a 1991 4Runner with a 3VZ-E and R150F transmission and swapping to a 1UZ-FE with an R150F transmission.
I sent an email to Dellow Automotive in regards to my swap and they sent me a list of parts and prices of items required for the swap.
Their list includes:
Bellhousing
Pilot bushing
Clutch fork and clip
Clutch Plate
Flywheel + bolts
Pressure plate
Push Rod (adjustable)
Thrust Race and Carrier
Slave cylinder
Push rod
Now, I'm no expert so I could use some help on the parts that I'll actually need from them. Obviously, one of the main components I need will be the bellhousing and flywheel. I was planning on sourcing my flywheel from SuperRunner, so I crossed that off the list. As it were, my 4Runner already has a slave cylinder which should work fine, so I should be able to remove that off the list. The clutch fork might be necessary if its a different length (again, I don't know). I realize that I'll need a clutch/pressure plate and whatnot, but shouldn't any R150F clutch work? Can someone who has performed the swap chime in please? Thanks y'all. Take care, Eric.
Bellhousing
Pilot bushing
Clutch Plate
Flywheel + bolts
Pressure plate
Slave cylinder
Push rod
