iaksa
- Messages
- 47
- Location
- Randolph, NJ US
My problem is running lean on one side of V8 under
7psi boost, after 5-6 second at 7psi. Car is running
perfectly in vacuum, first sec in the boost (7psi),
both side running rich. After 5-6 sec one side of v8
going from rich to lean.
Let me give you more info about my set up.
I had '93 sc400 with Richwood kit w/ M90 having
215K on it and I moved kit to another sc400 '93
with 105K miles, running little bit rich as stock !!!.
I replace/install: new plugs (colder with .033), new
wires, dis. caps, dis. rotors, left rear O2 sensor,
cleaned 315cc/min injectors, all -6AN fuel lines -
two fuel Y blocks adapters going to/from fuel rails with two
fuel rail dumpers. On return fuel line Vortech Super
FMU without OEM regulator.
Installed: Greddy fuel press in cabin gauge (100psi),
boost press. gauge, air-fuel LED gauge, catch can.
After installation car start instantly, 1200rpm - cold
and drop at 750rpm - warm. Adjust fuel pressure :
idle at 33psi and without vacuum at 46psi (from SC400 Manual).
I set up no limits (fuel press.) on SFMU under boost,
at 7psi is about 80psi.
Even my old car had bad idle, and new one perfect, I
think my old car pull much better. Old one had perfect
combustion, LED Air/Fuel gauge show all in green at 7psi
with stock injectors and stock plugs, without pinging.
I need definitely to put car on dyno to see what is going on.
May be it is time to change rest of tree O2 sensors, or some
other sensors, what do you think ?
Before that, can somebody give me a clue what else I can do.
Thanks, IAksa
Thanks, IAksa
