profile18
- Messages
- 38
- Location
- California,USA
I have recently put a 93' UZ into my 89' Cressida, everything seemed fine it was running good idled fine just had low oil pressure do to a oil cooler and relocation kit.
I put 5 quarts on top of the standard 5 quarts needed making 10 quarts in the motor, so i started it and let it idle to see if the oil pressure light would turn off and to check/ top off coolant levels etc...
It idled great for about 30-45 sec then just died, now it just cranks over and wont fire and sometimes spits smoke out of the intake.
note that i've started it before 3-4 times with no problems.
*fuel pump/ pressure is good.
coulld it be spark plug/wires?
sensors? (crank, cam)
Ecu?
Help!
Ecu?
Help!
