jonossiksilvia
hi all hope everyone had a awesome break over the new year etc.
being have issues with my 1uz starting and idling have so far spent 2 full days on this problem so far
google has been searched non stop.
it will not start unless ya foot is on the gas pedal and once ya have got it started it wont idle by itself for bout a minute.
i have removed the air control valve on front of intake manifold and gave it a good clean and when fitting a back up made sure the plunger is right in - great started easy and idled how i would think is should being cold. turn it off and started again and back to old problems
next up i got the truck warm up to operating temp and adjusted the tps to set the revs at 750rpm - sweet idles awesome, revs clean, no hesitation when off the gas pedal - just drops back down to 750rpm.
turn it off and try starting again - yes it starts and idles perfect. or so i thought
cold start again - wont start or rev cleanly wait till warmed up and guess wat the revs have reset itself to 500rpm ish
this time i manually set idle with throttle stop screw on left hand side of tb between traction unit and throttle pulleys to 750rpm - revs cleanly etc.
try restarting and perfect start and idle, wait till cold and it becomes a dog to start again and wont idle - wait till warm and the revs have adjusted itself back to approx 500rpm again
questions are:
1) how do i fix the starting and idling properly?
2) im guessing its the ecu resetting the idle every time? - have constant on ecu wired up
3) is it possible i may have missed a wire when i done conversion?
4) when adjusting the tps the range of adjustment is only approx 300rpm - this normal?
im really at a brick wall on this problem and really need it sorted so i can take it for cert.
any help small or big would be greatly thanked.
questions are:
