ATTENTION 1998 and New Lexus-Toyota V8 Owners:
If you own a 98 or newer Lexus or Toyota V8 engine and
currently having some type of forced induction such as
turbocharged or supercharged. The stock rods are only good
for about 450-500 rwhp and they will literally break on you.
If rod broke you whole costly block will be destroy. So
don't take chances and ruin your beautiful engine. I have
a friend own a junk engine yard and every Tundra blocks or Lexus
(post 98) engines. Almost all of them have broken rod or
rods. The combo below are the toughest available period!
Please read more about
Lexus and Toyota V8
Rods in here.
We want to be the leader in built Lexus-Toyota V8 engines
authority. Therefore we are offering something you have
never seen before. We are offering pistons/rods
combination. If your budget doesn't allow you to purchase
a complete built forged long or short block and the rotating
assembly might not what you want. Here is your chance to
get something nice and eliminate days of research and headaches.
My goal is to eliminate your headaches. We are offering a
forged pistons/rods combo.
Pistons: The pistons will be custom made specific for your
application. Please see this link for more details on
custom forged
pistons
Rods: These forged H-Beam rods are custom made specifically
for Lextreme with ARP L-19 rod bolts
and the bolts are good for 1000 hp. No crank modification is necessary. We
named these Lextreme Lightning Rods. These rods are custom
machined to mate with stock oem bearings. They
will bolt right onto your stock forged steel crank. Please see
pictures below.
Please let us know your compression ratio and over bore
desire. This combo is balanced before shipping. This
package is an unbelievable and insane price is only for $1,995.
This is a small price to pay if you compare other I Beam rods
are about $1,500 a set. You are getting high performance
quality custom forged pistons to your specs plus steel forged H
Beam Rods with the strongest ARP bolts available. With my
package and your stock steel forged crank and the legendary
Lexus 6 Bolt Main or the Toyota 2 Bolt Main and all you need is
Fuel, Ignition, Air and a lot of Tuning. Here
is what you get for your purchase.
- 8 Custom Forged pistons with any compression ratio and
bore size
- 8 Sets of performance piston rings
- 8 Performance piston pins
- 8 Lextreme Lightning Forged H Beam rods
- 16 ARP L-19 rod bolts
Due to complexity of Toyota bearings. We highly
recommend you call your local Lexus dealer and give them your crank number and rod number to get the
proper size
bearings. The rods are capable of 1,000 hp with ARP
L-19 bolts. However, we recommend you coat your rod
bearings for high performance hp goal. Please allow 8-10
weeks for delivery. Slightly extra for outside of United
States shipping. $1,900 USD
2UZFE motor such as Tundra, Sequoia, 4Runner and LX470 will be
an additional $150 because of the rarity of rings size.
Lextreme Lightning Carrillo Rods/Pistons Combo:
Yes, its real Carrillo forged H Beam Rods with SPS Carr bolts.
They normally run for about $2,200 a set just for the rods.
We have modified these rods to work with any Lexus-Toyota V8
engines. With these NHRA rated rods along with Ross custom
Forged Pistons with upgraded pins and rings. This combo is
the toughest money can buy for the our V8 engines. With
rods running for about $2,200 and upgraded forged pistons is
about $1,250. We are selling this combo for $2,699 plus
$50 shipping with in United States or $120 shipping to out of the
country. Special on the rods are hard to come by so please
email me so we can put you on the waiting list.
Different combination of block-heads also available. Any
Lexus-Toyota V8 engine for $2,699 plus shipping.
