Which cam sensors gives me TDC
Glen75
Guys, i'm about to start wiring up my Motec to my 1UZ, i have already bolted the covers over the dizzy's etc, and i cannot be bothered lifting them to look for myself.
Which bank gives TDC reading and which one reads on BDC?
Thanks Glen
Everyone I know uses the left bank (1-3-5-7) for the trigger.
So I'd assume thats the TDC one.
(note, neither occur at TDC or BDC, its about 30deg before or so)
Sweet, thank you. I can account for that with my Crip setting.
Cheers Glen
I just had a look on another file from a 1UZ that runs Motec, and it's Crip was set at 6Deg. Are you sure it's 30? or could it be 6?
Cheers Glen
Glen,
It does not matter which cam you use, The file you have is for the LHS cam, If you used the RHS one the crip would be 366.
you just need to wire the injectors & ign 1 & 2 the right way.
SprinterTRD said:
Glen,
Thank you.
Is this ST?
Some more info
Not everyone...
