jibbby
- 3,824
- Santa Monica, California
Loroh - A clean rag and WD40 will not clean the throttle body behind or around the TB fly. and I am not so sure a WD40 residue is a good idea to leave on the inside of the throttle body......Carb cleaner sprayed generously will clean and lubricate the throttle body and fly just fine...You can take it step further as stated in the link and clean the MAf, sensors, snorkel tube, etc..but that is more cleaning then just the TB and in most cases not necessary...The dirt and or film build up on the inside of the throttle body and fly is what causes the idle to bounce and or idle poorly in most cases...By spraying the inside of the TB and fly you are removing the dirt and grime buildup so it will function correctly and flow more smoothly..The throttle body fly will not be resticted any longer from opening and closing.....When doing this proceedure while running the motor, everything is sucked through the intake and motor and out the exhaust. (You may stall out a few times but that is ok) ..By doing this procedure without the motor running you are essentially flooding the intake with carb cleaner and may have difficulties starting the motor for a while. You may even experience a back fire until the intake is all dried out...Plus when not running the engine the dirt and grime really isn't completely removed and just puddles, but even that should do the trick......Fella's it's not a big deal and I can clean out my throttle body in about five minutes......I have been cleaning throttle bodies on these Sc's for years and years...90% of the time I get positive results...Just ask any mechanic and they will tell you the same...
Your intake is usually the culprit for a bad or rough idle, also a vacume leak can be the problem when your car is stalling out at idle...Other stuff can be the problem but is not common...TPS, ECU, MAF, Electrical, etc...
