MacroP
- Messages
- 87
- Location
- South West Oz
Greetings all.
Just hoping to get some more knowledge of the various Toyo transmissions and what is their operation, for my project.
Currently, in my garage, I have a 92 1UZ from a Soarer a.k.a. SC400. The engine was removed from a wreck along with it's transmission, A341E / A30-41LE. It's been stipped down, rebuilt and is ready for starting.
I've also picked up an auto tranny that came froma 91 Hilux Surf that is marked as a A30-43LE(Aisin number?) so I guess this makes the unit a A343F in Toyota lingo. This unit has a mechanically operted low range setting, having the F desgnation, vs a hydraulically operated transfer has a H designation, ie A34xH.
My project involves putting the 1UZ and auto into a 1988 75 series Landcruiser ute, hence the need for the 4WD tranny. I pretty much have every thing ready to go together just waiting for an easy few days.
In a previous post, Lextreme member 'madmont' has successfully mounted a transfer box (A340h) to the original auto that came from the 1UZ. This required the transmission output shaft to be changed, which is turn requires the entire gearbox internals to be stripped out. Something I'm not confident about doing, just yet. I am, at first, planning to use the entire trans/transfer a go. Obviously, the bell housing's need changing over. If this doesn't work eventually then I'll have to fit the new Trans. box to the orignal Soarer transmission.
The difference between the two trannies, apart from the obvious inclusion of the transfer box, is that the Soarer box has a 6 pin solenoid connector, where as the Surf box has only a 3 pin connector.
4 solenoid vs 2 solenoid?
The actual gearbox cases are identical.
From what I've read, the Soarer has the standard 2 solenoid drive setup (S1,S1) aswell as a T/C Lockup solenoid (S3/SLU) and a Line pressure solenoid (S4/SLN) which regulates shift quality/attitude? Both the latter's are a PWM proportional setup.
My surf gearbox only has a 3 pin Solenoid connector, meaning to me, that it only utilises 2 drive solenoids and goes without the T/C Lockup and shift quality setup?
Apparently, some Toyo 4WD boxes have a hydraulically operated low gear in the transfer box and use the S4 Solenoid of the main trasmission to engage low gear. Later/newer 4WD boxes utilise the S3 solenoid for TC lockup too.
The transfer is also missing a second speed sensor output. The primary, gear driven, unit looks to be quite compatible but the box is missing the second, magentic type. No big deal though, really.
My plan is to connect the original Soarer loom to the older type 4WD trans. The Soarer enigne has an integrated ECU/ECT and, apparently doesn't like the gearbox to be not present. To what degree is what I'm asking? No primary solenoids,S1 and S2 present!
I understand the ECU/ECT monitors the conitinuity of the available solenoids?
At which point does it spit the dummy if they are not present? S1+S2=Good pehaps where as no S3 or S4=bad. ?
I was thinking, as to put a dummy load on the wiring loom to simulate the now mssing S3 and S4 soleloids. I wonder if this is enough. I'm curious as to whether the ECU/ECT monitors the input shaft vs output shaft speed relationship, to verify if the trans. is actually working correctlty or NOT.
