LondonBenji
- Messages
- 284
- Location
- London, England, UK
5L, 800(ish)bhp and 620kg's? Oh holy crap.....
The Can-Am Porsches of that era had the Toyota 7 beaten by an incredible margin:indeed HOLY crap, and availeble in seven different colours down your pants, I presume,
I know of no kitcar with those values and they have build some crazy stuff over the years.
grtz Thomas
Q1: what would be the + in running ITB's and turbo's instead of turbo's on plenum chambers?
a true twin entry without balance pipes has to my knowledge (which could be wrong offcourse) never been used in a race car exept the audi R 10 diesel car, which I looked at quite good at le-mans last year but couldn't find a balance pipe between the chambers note that diesels don't have air throttles. AER tried in the past on gas engines but reverted back to balance pipes after testing proved not competitive vs balanced, I dont know why though.
Q2: so what is the point in actullly doing that set-up?
or are you only triyng to improve equal flow in all cylinders using a tappered plenum form? in that case look at test done with laminova IC's the equal out almost everything if they can be mounted close enough to the head ports.
seems also that the vvt heads are better because of the steeper angle of the ports.
grtz Thomas
Skyline:
