lexus surf
I have put this question in the transmission section but recently discovered 4x4 section so i'll ask here as well
HI ALL,
Was after info on whether my theory is viable or not,
I am wanting to transfer a lexusV8 into my v6 surf and retain the tranny that comes with the V8 since the ecu controls it, I read that the output shafts and tail housing can be swapped from the A340h into the V8 tranny, to be able to fit up the transfer case. But not wanting the hydraulically operated low range was wondering if the A340F will have the same outputshaft or if it can be swapped into the V8 tranny, since they are very similar. I am wanting to retain manual shifting of transferbox. This will leave with an option of later upgrading to dual transfer cases. would i be right to assume this? and will the A340F handle the power?
