Just call me "Lex"
- 12,033
- City of Halos
Oops... sorry...
No problemo, I was only joking, even though there was a little truth in it...Lextreme said:Oops... sorry...
Bob, thanks for the kudos...By itself, it should handle 550 to 650 HP or so, maybe a little more depending upon tuning. Remember, the 900 HP decision came later, not with the original design, and 900+ HP is really only for the dyno numbers, certainly not for daily driving. I will drive the car around with the boost set for approximately 600 or so WHP. I haven't made a final decision yet, but to boost beyond that HP, I wil either make a new and larger intercooler, or add alcohol injection. Probably alcohol...rdm20fan said:I like the bar n plate intercooler ryan, and the dual inlet in the bottom, and I'm assuming single outlet on top.
Very nice peice, n design.
I need to change mine from a tube n fin, to bar n plate cause of the HP the motor is making.
My intercooler is 32x24x3, and is only rated to flow enough air for 600-650HP
Now a bar n plate is more effecent, but is that intercooler going to support the 900HP your looking to make?
Yes I have, Split Second Piggyback ECU with external MAP sensor...Turbo4L said:have you decided on a computer yet?
3 inches...how thick is the core you are using?
I am confident it will handle more than 650 HP, but I have to test it and see...having a core sitting top to bottom like that i don't see how it won't be good over 800whp.
Mine is similar to yours in size and dimension...I will have to measure it again, as I do not remember all the dexact dimensions...the car that I'm working on. its cooler core size is 28.3 wide 12" high and 3" thick(top to bottom).
this core would handle 1000whp no worries.
Running eight additional injectors, 550cc...The stock injectors will remain. 2 WALBRO fuel pumps...what size injectors are you going to run?
we'll be running 8x1000cc injectors, and 2xbosch 044 fuel pumps.
Custom plenum...Turbo4L said:Its good to see someone having a good go at turboing the V8.
I'm keep to see how it all turns out.
i would have thought that the turbo's you are running 2871's? you wouldn't be able to get to 900whp.
I'm sure you may have mentioned that before.
Are you running the stock intake plenum or are you doing a custom one?
Bob:rdm20fan said:I like the bar n plate intercooler ryan, and the dual inlet in the bottom, and I'm assuming single outlet on top.
650rw is around 800 at the crank with the Auto. It is very hard for me to belive that that intercooler is going to flow enough air for 800hp, let alone cool it.SC400TT said:Bob:
I contacted the engineer at Bell and he informed me that my intercooler will have no problem in handling up to 650 RWHP. Which is well within the original goals I ahd set up of 500 RWHP. I have done a little more investigation, and I have decided that I am going with Water Injection instead of alcohol. It will give me much more efficiency, and I do not have to augment my intercooler to spend money on an intercooler that will only occasionally go higher than 650 RWHP.
Ryan
i know that about the fuel and the turbo;but , what i wanted to know if there was a more fuel efficent turbo kit that's what i find most interesting. if not with water or methanol injection then how???????? what a tornado fuel saver in a turbo hahahahhahaha.i want 2 add more power.but, the thought of paying the oil companies more money kills me.rdm20fan said:Hey robbie, not to rob ryan's post, but no the trans will not handle the power increase. the trans needs to be upgraded.
to answer your question about fuel mileage, is do not install a turbo/supercharger if this is your worry. my gas mileage has probably cut in 1/2 or more.
can you make a setup a little more efficent, sure, but there is a formula for the amount of fuel that is required to make power. if you want more power, you need more fuel.
Thanks for the input Bob...At this point, we will just have to wait and see...The car will be done in a matter of weeks, and I will do my tuning and final set up on Stage 1 and then Dyno it. What I get is what I get.rdm20fan said:650rw is around 800 at the crank with the Auto. It is very hard for me to belive that that intercooler is going to flow enough air for 800hp, let alone cool it.
I don't think a water/alcohol injection system is a good idea on the stock manifold, unless you do injection into each runner.
Cylinder 3 & 5 are are going to get lots of water/Alcohol, and cylinders 4 & 6 are going to get very little. the manifold is designed to flow air, not a liquid.
I have a feeling the heavier liquid will flow straight into the side wall, and go down runners 3 & 5
The later front inlet would be better, but the rear cylinders would still get more water then the front.
Good answer Bob...:veryhappyrdm20fan said:Hey robbie, not to rob ryan's post, but no the trans will not handle the power increase. the trans needs to be upgraded.
