Procharged 1992 SC400 "Fish bracket setup"
Thanks for the good news!
I have not purchased the pump for this car yet... I may just pick up the denso instead of swapping my used 255. Thats quite a bit of flow from a single drop in pump. I doubt I will cross 500 but its nice to know there is room for more mods.
I believed she got parted out. Pulleys are easy, same as the belt.
If you're talking about the blower for the pulley, then whatever blower you get, the manufacturer will be able to get you the right pulley size. They'll need to know: boost, crank pulley diameter, and how many ribs, and they should be able to match something up for you.
As far as the belt goes, I just measured it with a long piece of string and went to the auto parts store and picked one up.
Not quite, mechanically it is done. I have my injectors, map and iat sensors here. I was waiting on my usb->serial from Jaycar. It came from Australia today. I've gotta finish up my Z (the reflashed ecu and injectors made it!), once my S30 is on the road, I'll put the SC down to finally finish it up.
