Staff,
Ok, not to be a doubter or critic off hand... I must say that polishing intake passages to a mirror finish has not been advocated by any professional head porter that I have ever spoken with or read about in the 30 years that I have been fooling with engines. That said I am always interested in seeing people test ideas and theories as long as they do so objectively.
Now, regarding the leading edge of the port divider... virtually all aerodynamic models suggest that a sharp edge is not the most efficient shape. This is why airplane wings are not shart on the leading edge but rather on the trailing edge.
Your power claims are impressive. Do you have the dyno sheets for baseline and post mods? You say you gained 40rwhp. Is this combined with intake and exhaust mods or heads alone? Your math above suggests 30-48 horsepower for a good exhaust and intake filter modification. What exhaust mods are you running.
I guess the bottom line is... obviously you have put in a great deal of effort. Your ports are certainly shiny. Please post your actual test results, theories, modeling, dynos, comparisions and so forth so that we can intelligently discuss your efforts. Without such information I am concerned that others will attempt to duplicate your results and end up spending time and money and only loosing power
Wurf, the stock heads are not the first restriction. The exhaust is the biggest bottleneck. Remember here that bigger is not necessarily better and in fact with only 4 liters to move the roughly 4000lbs that most of these cars weigh... your goal should be maximizing mid RPM torque and not loosing low RPM torque. This is best accomplished with a high velocity exhaust system including manifolding. Unfortunately proper headers are not sold anywhere and therefore need to be fabricated. You may wish to weigh the cost of this with the supercharger/turbocharger systems Lextreme is working on. Another mod highly recommended would be a higher stall torque converter. David can help you there as well.
10/07/05 UPDATE: Headers are now available from S&S Headers, www.ssheaders.com
