Please Help to make my SC430 gain HP
jasontan
I have a 2002 Lexus SC430, I have done all the exterior work on the car. Now I need to increase the HP. I have recently installed a blitz intake, but I feel no gain in HP. Can you please advise me on how to make my UZZ40 engine gain in HP.
Jason
Intake might give u 5-8 bhp and you will not feel a thing. Exhaust would help but the noise factor i would stay away. I would recommend NOS. 50 to 75 shot would be great.
Jason,
The only way you would get any noticable power would be a combination of openinging up the air intake, ensuring you get the coolest air possible into the inlet, a set of headers with appropriate pipework and mufflers plus new cams.
All this may put the engine outside the computers ability to run it as it may flow more air and need more fuel than it can supply.
Replacing the computer on a 430 looks like an impossible task.
An M90 and 6lb boost would be my inclination. Looking at the height of the 430 plenum the M90 would fit under the bonnet easy.
how much money do u want to spend
u will need minimum 4000 i think to do anyhting worth while
if u dont want forced induction then u can go
8 throttle bodies which sound awsome
but for a good setup u need 8000 by the time u get manifolds throttle bodies programmable ecu then u have to worry bout the gbox control too
just remember anything u do thats small will cost more than its worth
like intake box or exhaust
like i tell most people
you either leave it alone sort of std
or you spend over 5000 to make it worthwhile
the problem with these engines is that theyre auto and when u go aftermarket ecu it causes more headaches
all which are easily overcome but at a hefty price
From the sound of your post I am guessing that you do not want to dramatically alter the car... instead... just gain a modest amount of performance. Is this correct?
Let me say that when Lexus increased the engine size from 4.0 liters to 4.3 liters in 2001 (2002 for the SC430 as there was no 2001 model) the torque rating went up from 300 to 325 but the horsepower only rose 10 from 290 to 300. Part of the reason was that Lexus went with a more restrictive exhaust manifold (single vs dual tube header design) which kept the exhaust hotter and therefore made the catalysts work sooner. They also kept the same camshaft lift and duration. So, there is definitely room for improvement.
I would recommend the SRT intake and race ECU for the GS430. Keep in mind that it will need some modification as it is not designed for the SC engine compartment but the important thing is the larger flow area and the recalibration to the MAF sensor. This should be good for 15-20rwhp.
http://www.swiftracing.com/vehicles/lexus/gs/intake400.htm
As I said above the exhaust manifolds are restrictive. A properly designed set of headers would definitely wake up this engine. Unfortunately there are none available. You could have them custom built at Burns Stainless or Stainless Works or some other quality shop. Headers and proper exhaust should be worth another 20-40rwhp.
Much more available would be a higher stall speed torque converter and/or higher ratio differential gears and optional limited slip either torsen or clutch pack. I am not positive but think that the Supra twin turbo automatic torsen limited slip differential assembly will fit your car. This will change your gearing from 3.266 to 3.769 for a resulting increase in rear wheel torque of about 16%. When the GS400/430 guys make this change they see there top speed reduced from 149mph to around 130mph due to the factory speed limiters reaction to the gearing. I do not know about the SC430 which has a none modified top speed of 156mph (electronically limited).
The torque converter will launch the car MUCH faster and provide faster downshifts and gear changes. Some GS430 and SC430 cars have had this trigger the check engine light even though nothing is changed or endangered on the engine... it is merely the electronic sensors showing outside the accepted parameters. Some have had Precision Industries set the stall speed at 2500rpm instead of the 2800rpm that the GS400s run and that may solve that problem. A torque converter will cause moderate throttle driving to feel looser. Light throttle will be unaffected and full throttle will be dramatically improved. Do some searching at Club Lexus in the GS forum for more info.
Lexus lists the stock performance of the SC430 at 5.9 seconds 0-60mph and 14.4 seconds in the 1/4 mile and I would estimate at around 98mph. If you did all the above mods and learned how to properly drive the car at the track I would suggest a very low 5 second 0-60mph and a mid 13 second 1/4 mile at over 100mph... probably around 103-105mph.
If you want more I would recommend the low mount turbosystem from XS Engineering or a properly designed nitrous oxide system. The nitrous could be done first but has limited drivability and of course is subject to a full bottle of NOx.
Lexus SC430
I would like to know where to get the torque converter, and what is the exact kind to get for the SC430 as what u hv recommend
for a easy exhaust mod that wont make it any louder i would remove the third cat. converter and replace w/ a straight pipe, if i remember there is no 02 sensor after the 3rd cat, and if there is by chance an 02 simulator from xerd or such will take care of that. power i dont know for sure but a definite improvement.
