P Bateman
I need to return some videotapes.
If you are running aftermarket engine management (or plan to) this is a must.
Using the factory stepper motor consumes 4x output channels, where this unit only requires 1x, leaving you free to assign outputs to other functions.
The stepper motor itself is simply a Ford Idle Motor, but it's the adapter plate that makes it work.
Bolts onto the original mounting studs, clear of all vacuum ports, CNC machined, anodized silver.
I've been using it since 2024 and its never missed a beat - upgrading to DBW throttle and no longer needed.
Comes with:
Comes with:
- Modified throttle body (TRC throttle plate removed and a barbed fitting tapped in)
- Silicon hose + clamps
- Throttle Position Sensor + connector
- Haltech air temperature sensor + connector
