how did you go with your issues???....listen to what jim says, i had the same problem and solved it myself and i'm and old fart that's only ever played with big block chevs and carbies.you've been told how to fix it, check the diagnostic box with those connections and i'll put money on it that it's a black/red wire at the ecu that req's power with key on, not crank....it will supply power to 4 inj, the idle air motor and your airflow...check for brittle wiring too, i found a lot of wires that haven't stood up to the heat real well and have cracked the insulation and corroded thru...if not pay the money for the alldatadiy.com schematics, they are the factory diagrams and once you figure out how to read 'em it's simple as........
