I am from South Africa and am planning to build a offroad 4x4 vehicle. I have decided to use a 4 liter lexus v8 which I can get from the local importers.
I need some info to complete my planning -
1. The original toyota/lexus ECU - does it combine the engine control as well as the automatic gearbox control in a single "electric box" or are they seperate?
2. How easily can cruise control be incorporated in the design?
3. Can a tiptronic/paddle shift system be incorporated using the auto gearbox that comes standard on the engine? Would one need a special gearbox controller to do this and if so is it available?
4. I doubt that I will be able to get a working original ECU in SA. Unless I can source one from overseas I will need to get an aftermarket one. This is possible. The transmission controllers in South Africa are however not so good. I assume that someone would be able to ship me one from overseas if need be?
Thanks for you advice!!
