CoffeeAddict
Hi
I'm sorry I've been lurking around for a while and haven't introduced my self properly. I guess I was kind of hoping I can sneak in, steal all the info I need, and sneak out, without having to embaress my self with all the nube questions I'll be showering you with shortly. How do you do
Before I get on with my questions, may I thank you all for this great forum - probably one of the best, most informative and educational I have come across.
Alright, here's the deal. So I have no mechanical knowledge whatsoever - despite being a mechanical engineer, ironically - and I would like to start working on a project, and maybe build my own track/race/fun car. Long story short, I had my mind set on swapping a 1UZFE from a '94 LS400 into a '79 RX30 round-eyed Cressida. I thought I would use the original drive train - automatic tranmission, driveshaft, differential - to avoid as much complications as possible, add a paddle-shift conrtoller, maybe strip out the interior down to metal, and fit a couple of race buckets, a functional aftermarket dash perhaps, you know. If things go well, I might even throw in some expensive performance brakes and suspensions, light weight wheels and expensive tires.
Now, kind sirs, to the first and most important question; Is this even possible ? with zero mechanical experience (I mean zero !) ? with all the electric wiring, and the ECU reprogramming or whatever is it it'll need to get us moving ? And with all the fabrications and modifications ? I mean I guess I can pay to get whatever I couldn't do my self done, but if at the end I'll end up paying for the whole project to be built for me, I will have missed the point completely - this was intended to be a cheap junkyard project, built in my back yard, with the help of whatever I can get my hands on from internet websites, manuals, DIY's, etc. Money is not an issue, though.
If your answer is No, then kindly answer question number 2. If your answer is Yes, then kindly answer the rest of the technical questions - 3 through 6.
2- If you don't think this is a good idea, and it's not possible for me to go through something like that, what would you suggest ? I wish to fit a V8 in a RWD, ridiculously light weight, preferably Japanese and understated, sedan. It needs to be a junkyard cheap save, and it needs to have a good chassis that handles.
3- What will I need to do with the ECU ?
4- Since I'm not planning on going stock, will the tranmission and differential take up to at least 400 HP ?
5- I don't want it to be an automatic, and I don't think with my level of expertise I'm capable of doing the mods needed to mate the engine to a manual (W58 I bilieve is the popular choice ?), so a controlled auto is my best choice. So how quick can the gear shifts get with whatever's the best controller out there ?! and actually what IS the best controller out there ?
6- Where can I find all the literature I need ?
I EXTREMELY apologise for my lengthy post, expressive abilities reduce to half when you're sprinting in a second language which brings us to the second apology; sorry about the poor English you had to soldier through
and many many thanks in advance !
Good Day,
Good Day,
