hey,
daft question time i'm fitting a 1uz to a LJ70 land cruiser and want to use megasquirt, i figure that i want the basic system as its just for an off roader so ms1 with edis wasted spark , and i think i need a trigger wheel which i can make from a universal one, crank sensor, coolant sensor, air temp sensor, and an o2 sensor
questions are do i run 1 or 2 o2 sensors?
i take it the missing tooth goes at TDC piston 1 on the bang stroke?
do i need a throttle position sensor?
I read that GM sensors are compatable with MS, so if i go down the breakers and whip the temperature sensors, o2 sensors and crank sensor from a petrol vauxhall will they work?
when i get all the wires to the right place, connect the battery, stick the key in and turn it.... will it fire? or do i need to program data into the box of tricks?
sorry if this seems like i'm not trying to look for the information myself.
cheers much,
Ali
			daft question time
 i'm fitting a 1uz to a LJ70 land cruiser and want to use megasquirt, i figure that i want the basic system as its just for an off roader so ms1 with edis wasted spark , and i think i need a trigger wheel which i can make from a universal one, crank sensor, coolant sensor, air temp sensor, and an o2 sensor  questions are do i run 1 or 2 o2 sensors?
cheers much,
Ali
