I am looking for ONE 14" high CFM electric fan. I have seen as high as 2,500 cfm. Any recommendation? I have dual pushers already but not working too good. Need a high performance puller.
You are full of wisdom. It is rated at 4,500 cfm. HUGE if that is correct
I don't have room for a radiator that's thicker than OEM size. Therefore, I went with an aftermarket aluminum core radiator that's the same size as the OEM. It helps dissipating the heat quicker than the OEM, but the heat is still there because the skinny fans just can't blow the heat out of the engine bay. And the other main heating factor is because the turbo system takes up too much room and restricts the air movement. Actually, the best fan is still the stock hydraulic or clutch fan.Steve, have you tried a 4 core Koyo rad for the Supra yet? Those are supposed to support massive boost/heat.
as for my procharger, I can WOT several times and still grab the compressor housing with bare hands w/o burning. i'd trade some of that for your quicker spool tho![]()
Got the fan a week ago and open yesterday with Steve. It wont work for my application. For sale if anyone need it.
