also as rear sump engines are getting REALLY hard to find is there still much work modifying cross member to take a front sump model??
they are the few things i am trying to get my head around at the mo...
any help would be awesome!
hey, ive heard ya can spin the cross member 180 and run a front sump but then ya have to mod the control arms a little... im running the 1uz auto and ya have to run a slip joint like on a 4x4... the hardest part for me was wounting the throtle body etc so the pan under the drivers seat ect clears everything... ill post pics if ya need to see anything man....
spinning the cross member is not a good idea. Cert guys dont like it and why reinvent the wheel when Rear sump motors are still around. I have two rear sump setups in stock at the moment. You can also get away with a mid sump if you really have to. I would make new custom sumps before spinning the cross member.
Rod - you dont ran a crown box you fit a 4x4 type slipper in the driveshaft. Hiace arent too hard jus take lots of time. I have a photo here of one.
all i said is that ive heard of it being done because rear sump motors are getting harder to find....and those that have them will rip you off blindly for them.... there is definitely more than one way to skin a cat![]()
Totally, I tried first off spinning the cross member and F'd up something chronic, in the end a work mate helped me make a cross member to suit a front sump out of two Hiace cross members. And end result looks factory. Now when/if I ever need to throw another engine in I can get a common front sump
I used the ones I got from Kelvin @ Cartune a couple ears back. They place the engine at the perfect height.
With the radiator I'm using the one I purchased for the stock 2L engine a tad before I decided to throw in the 1UZ in. Ive got 2 electric fans running on it but from what Ive heard maybe going with a radiator to suit the 3L turbo diesel would be better?
cos I wana run front sump, jus becos the are easier to come across, and really try and do it on a budget in a way, like if theres things I dont Have to touch Ill try not too. Ive been told I can use the g55 box, I have a belhousing to suit already, did you have to mod gearbox x-member? and driveshaft or can they all bolt up again, without shortening of lenghtening?
Dude I fully know how you feel, I started off doing mine with the same mindset.. Any conversion on a budget is where it's at lol.
You are OK to use the G55 believe it or not. Not 100% ideal but unless you are planning on ripping the shit out of it constantly (and for the first few months you will want to) hen it should hold up fine. I met another guy down here who has done the conversion and he has been running his G55 with no issues for afew years now. Try Performance Motor Works for an adapter plate if you need one.
Only thing you may find with going for a front sump option is that you may offset the extra you would ultimately pay for a rear sump on creating a cross member to suit the front sump ...... unless you are able to fab one up yourself.
With the mounting of the gearbox.... well really cant vouch for everyone elses but mine pretty much lined up with the stock mount just needed abit of fab work here and there.? and no mod to the drive shaft either.... Yes I was surprised too.
