Marknixon91
Hi iv done a 92 1uz swap into my Hilux the timing belt was done new leads spark plugs caps have been replaced in the ecu the issue is it’s had to start I need to spray start ya Basted into the intake to get us to start when it’s cold once it warm it starts fine. Once it’s running it will idle fine but when I give it throttle to quick it will die and misfire iv put a timing light on it bridging E1 and TE1 and it’s showing up just under the 5degree mark then when I rev it it moves to 0 what could be causing this thanks
