StacytheBloke
- Messages
- 51
- Location
- Staffordshire Moorlands, UK
I have a UK 1993 LS400 engine and auto gearbox with a cut loom. I have both halves of the loom and the original ecu.
I have being trying through lexus to get the ewd for the car, initally the guy messed up and ordered EWD225Y or EWD255Y which is for a later UCF20, he the corrected the and ordered EWD080Y which arrived and was for the correct vehicle however this book only contained the ECU pinouts for the ECU with four grey two row plugs and not the 34p,22p,16p,28p configuration i have. There are suppliments to the manual available however these are now discontinued, like the two manuals above (they were old stock) and there are none left anywhere in the UK. This is all because the whole system has been computerised. And they said under no circumstances can i even see the computer system (copying it down onto paper out of the question then) :rant:
unfortunately the pdf diagrams on here also fail to match mine
the ecu can be seen here
http://lextreme.com/forums/showthread.php?t=3348&page=2
I have created a spread sheet in excel with the colour of the wire exiting each pin. (each connector is on a different sheet)
http://uk.geocities.com/[email protected]/ecupinouts.xls
i do have the chassis number for the donor car if that is any help
JT153 UF1000175719
Do any of you have any suggestions as to where i might source the nice colour genuine toyota wiring diagram for this car. Please note it is European Right hand drive spec.
Thanks in advance
JT153 UF1000175719
Thanks in advance
