So lets see, the three fuel variables are 1) Injector flow rating, 2) Fuel pressure, and 3) Duty cycle.
If the injector duty cycle is safely maxxed out at around 85%, using stock injectors, what is the addition of X more pressure going to do to the available hp?
I've played around with this, while still remaining in open loop, passing smog and all the good stuff, and it's not that easy to do, but still possible with the stock fuel pressure regulator(modified).
I'm wondering if the same thing would work as smoothly on a mildly boosted car, by using boost pressure on one side of the fuel pressure regulator daiphram, as mentioned above, or if it would just toggle in and out of open loop/hiccup?
I wonder about this especially since the air measurement will be skewed, since air will have different volume/properties while under pressure(vastly different fuel curve). This is the same reason carbs don't work so great under pressure.
