Well i have embarked on put a crown 1uzfe into my hilux surf.
The g'box ect is really giving me the sh!ts and I would like to get to the bottom of it.
I have a half cut and have access to all the wiring harness, so any wires that you need traced let me know and i will only be too happy to tell you.
In one of your posts, you mentioned that you put a 4p/r into the SP1 of the ect. But on your diagrams you said it goes to the ecu (this is confirmed by tracing it). Which is the case? it seems too easy that all you need to do is hook up a signal to one wire? everyone makes out its so comp!
Also, would i be correct in saying that, if a wire from the ect (or ecu) gets split into 2, that would be an output? Doesnt seem right that a signal could come from 2 places?
I would like to get to the bottom of this ect so anyone can hook up the ect without the need for abs, cc, dash ect.
P.S/ Fant job on the diagrams!
