Alright, finally got some time this weekend.
Made a new cold start hose. Bought some 8mm banjo to 1/4" barb adapters, a chunk of 1/4" fuel injection hose, and a crimp-style clamp set. I'm quite happy with the results. The larger diameter hose did prevent the banjo from sitting flush on the rail, so I stacked an extra crush washer under the banjo to space it up. I don't love it, but I pressurized the system and it didn't leak.
2019-04-15_08-46-36 by
Numbchux, on Flickr
And, I ran it on the stand. I pulled a fuel pump out of a Subaru parts car I bought recently, first I hardwired it just to pressurized the system and look for leaks, then wired it in to the controller. The ECU connector with the bolt through it was not plugged in all the way, so it didn't pop over right away, I tightened that and hooked up my timing light to check again, and it started right up. Scared the hell out of me!
I had the radiator hoses hooked to a bucket of coolant, so I was able to run it for probably 20 minutes or so (and even then, the thermostat only barely opened). Seems to run really well, revs well. I took a few videos, I'd like to edit it a bit before I upload, so hopefully I can do that this week. One cylinder on the LH bank seemed to drop for 30 seconds or so, but the plugs and wires are not in good shape, so I'm inclined to think that's the culprit.
So, I ordered another round of parts (including plugs and wires). And I started taking the ECU apart to replace the capacitors (Even though I'm quite confident with my soldering iron, I wanted to make sure it ran before I messed with anything).
I was hoping to keep it simple, and keep the engine/transmission bolted together. But I do want to install a shift kit, and swap the shift shaft for a 4WD one to relocate the linkage to the other side. Looks like this all would be much better done with the transmission upside-down.....
