Mikebratty
- Messages
- 2
- Location
- NZ
Hi
My name is Mike.
I have a 1992 toyota surf with a 1uzfe in it. Its running a standard ecu and manual gearbox.
It starts beautifully and runs rely well for about 10min but when it gets up to operating temperature it starts to hunt/surge when idling, it also starts to miss and will occasionally stall.
If i give it a little bit of revs it stops missing and hunting.
I have already replaced the ISCV and put some throttle body cleaner through the throttle. I have tried unplugging the AFM and it continues to have the same problems. Any help will be much appreciated.
I would have thought if it was a coil bank it would fail under load?
Is it likely to be an ECU problem?
My name is Mike.
