Boosted2.0
- 91
- Houston, TX
Just a hint for the guys going AEM on boosted motors. It is WAY easier to tune your fuel curve if you use a 2D fuel map with boost comp and throttle comp. The 2D map winds up basically beign the VE curve of the motor. the Boost comp map is a straight line from 0 Bar to 1 Bar with it adding 0% at 0 PSI and 100% and 1 Bar. 200% at 2 BAR etc. Continue the line down to the left so that its at -100% at -1 BAR.
You then take the throttle comp map and use it to trim fuel below 40 % throttle - usually winding up at about 35% - 40% trim at fully closed and slowly curving up to 40-50% throttle where you are fueling at 100%.
Set it up like that and then set your main fuel map to fuel the same up the whole column for each RPM regardless of load. You will be able to dial in your fuel curve in like 6-10 pulls at the most.
