Backfiring and hesitation under load
Drain2
Hello all! Had to create a new account and decided a new thread would work as well
I have replaced spark plugs, coils, distributors, caps, rotors. And all 3 sensors and plugs with them on the cams and crank. I had a code 31 but that was resolved with new plug for MAF
Sc400 has code 13 hesitates under load and will not rev over 2000 in neutral or it backfires through exhaust. However the engine idles perfectly fine and seems like nothing is up until revved.
Any help? Thanks!!
Pull the plugs to see if you can identify a bad plug / cylinder not firing correctly. Also do a comp test. You might have a sticky / stuck valve. A misfire when you rev the engine is a sign of 1 or more cylinders not firing due to spark or being lean. A valve stuck partially open will cause this.
Already tried replacing with new plugs, it helped but didn’t solve the backfiring. I will do the comp test but the valves should be good as I just got the heads serviced. I think it is a fuel delivery issue. Occasionally when I start the car it takes multiple seconds to crank as the idle slowly revs back up to notmal
Code13 with log when the crank signal drops out (even momentarily) or when the logical pulse count from NE, G1/G2 is out.
When you clear the code, does it reappear immediately?
What has happened with the vehicle in the immediate days before this fault occurred?
How long ago did you have the heads serviced? Has there been any other work done recently?
Having replaced almost the entire ignition system and the sensors, if you still have a Code13 then I would suspect wiring.
I would start with resistance+wiggle tests on all sensor wires back to the ECU.
The heads were serviced pretty recently I just got the whole engine put back together and have had it started and drove a couple times, albeit with the code 13 the car still started.
Code 13 appeared initially after rebuilding engine then went away as I replaced most of the ignition system. Then it came back
The code would re-appear immediately even after disconnecting battery or efi fuse. Today I got a setup for a fuel pressure test ready but then the car wouldn’t start, still had the code 13 so I cleaned up the crank sensor and now that code is gone, along with both sub o2 sensor codes. However now I have a code 12 and only 12
Given the age of the car, and that you've recently disturbed all the wiring and connectors, it sounds like you have a poor connection.
Code12 will appear if the NE, G1 or G2 sensors are faulty, or if there is an open or short circuit in their wiring.
Given you've just replaced them, I would start with the wiring back to the ECU.
- Disconnect wiring from the sensors and the ECU
- Check resistance end to end - should be less than 1 ohm on all wires
- Check resistance to power/ground - should be open circuit
I checked the sensors resistance before I’ve left for school and the crank read about 2400 ohms. I’m going to remove some of the front loom and see if I can find any corrosion causing a higher resistance. Could it just be a bad plug? Should I still check for readings at NE G1 and G2?
It could be a bad plug... it could be anything at this stage.
Don't worry about the sensors for now (especially if you've already replaced them)
Focus on the wiring. Disconnect the sensors and the ECU - test the wiring between them
So the rear is leaking coolant. In between the tranny and the motor so I’m pulling it out and fixing that seal.
Since I’m already here…
I’ll check all my wiring with the harness in a more viable location and track down every single wire gremlin I can find. I will update soon.
i think I got ahead of myself so I did not pull the engine, however I found a stud on the rear crossover that wouldn’t allow me to loosen the nut. I figure this is my coolant leak and will try a pressure test soon.
On topic of the stumbling and hesitation I found multiple of my injector clips have wires showing and do not connect well to the injectors.
Does anyone know where I can purchase new injector clips?
Thanks, I’ll be replacing those soon, driver side wires were falling out of the pigtails.
Replaced the studs on the crossover as well. Will update again when I replace the injector clips
got the car put back together and it almost ran, I’m going to replace the iacv connector next as it is just as destroyed as the injector clips. Also when I try starting the car the rpm gauge bounces all over the place then the engine dies if that adds anything.
