Difference ECUs 89661-50241 and 89661-50240
When I first got my 1UZ it had ECU 50241.
Since then I have screwed up 3 ECUs.
Could not get hold of 50241 used 50240 in stead, to me seems the engine
is running just fine with 50240.
Although, I wonder if somebody knows the difference between the two.
The last number on the toyota part number is the supercession number. So the 241 is a later replacement for the 240. They should interchange without any issues.
What happened to your ECU's? I fix GM ECM/PCM's, I could take a crack at it if they are sitting collecting dust.
Collecting dust they are.
I have my 1UZ in a boat, the boat sunk, twice.
The ECUs didn't work after that, no surprise really.
One ECU sat on a shelf for 6 weeks, while I was out of the country, hauled the engine before I left.
When firing up again after returning the ECU works but only for 7 cylinders.
