Whats This From??
MaxPower
Hopefully someone can tell me what model gearbox this connector is from.. The gearbox is not the one that was originally attached to my 1UZ (from a LS400/Majesta, front sump) as i required a gearbox with the slip yoke year not the rubber coupling style. I have the harness from the Majesta but need these connectors - my bet is it is from a crown with the separate ECU and trans comp which means SFA chance of getting one at a resonable cost...
Solenoid connector..
Shifter connector...
Unknown gearbox
hi maxpower, just pulled motor and trans from a 91 soarer uuz31 gearbox has the same plugs as you have, its a model 30-41 LE S/N 91GE02069, hope this helps.
Regards
lambo
Cheers Lambo, good to know they are available from something other than a Crown. Of the 6 or so A34xE gearbox's a friend has none had these connectors so was a little worried!
Max Power,
I have a complete Crown ECT and Trans loom including plugs somewhere in my garage.
Let me know if you are interested.
If so PM me where you are and we can try to sort something out.
