Motion Software Dyno2003 Pro
John,
I've used Motion Software products for quite a while and have had good luck with Dyno2003 Pro. Same with this software, if you put in the correct parameters, you get a pretty accurate picture. I've actually designed and built an engine using the software and the numbers on the dyno were within about 4% of what the software said. Hope this helps...
Wayne
