The wheel base is 10mm shorter than the soarer but does not have the front and rear overhanges so car is about 450mm shorter overall
is about 100mm lower than standard PT so hight is not much taller than soarer
whent to wheel alignment today got everthing spot on but ran out off camber adjustment on front arms
can get camber right but then caster out so set with correct caster
camber will only cause a bit of tyre wear
must be the same with any lowered supra/soarer
does anyone make a camber adjustment kit ?
